Hi everyone.
Newbie question: is there any way to rip 5.1 channel audio from DVD?
I am using DVD2SVCD as a ripping program, and it does most of the work by itself. I am encoding the video with CCE2.5. For the audio settings, see the attached image.
I ripped few DVDs so far, but cannot make the ripped audio to be 5.1, as the source is. It always comes out stereo only. Is it possible? And if so, how? What I am doing wrong? BTW, I know the source is 5.1!
I checked the "Audio 1 downsample..." checkbox to avoid Nero from giving me an error message about the audio. It wasn't like that at the beginnig and it didn't changed the outcome.
Thank you in advance for your help.
I don't thank DVd2svcd surport 5.1 audio.
Try using DVD Shrink its free
Use this guide http://www.dvdshrink.info/reauthor_basic.php -
What are you trying to do with the movie? I don't believe that you can have 5.1 sound with vcd's or svcd's. Stereo is really your only option. If you're trying to burn a DVD, the standard ripping progs (dvdecrypter and smart ripper) preserve the 5.1.
newbie want to rip some vhs into DVD
By bambam in forum Capturing and VCRReplies: 5Last Post: 1st Jan 2011, 03:35 -
DVD with two audio channels
By Anurag in forum DVD RippingReplies: 6Last Post: 20th Apr 2009, 01:15 -
rip dvd folder and keep both audio channels ???
By hulinning in forum DVD RippingReplies: 12Last Post: 16th Feb 2009, 12:43 -
Rip Only Certain Channels From Dolby 5.1 DVD to Wave Files?
By dvd-dude in forum AudioReplies: 5Last Post: 3rd Sep 2007, 23:07 -
NEWBIE QUESTION about dark passages in a DVD rip
By pbecks in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2007, 08:50
Hi everyone.
