Here are my parameters:
Input format: MPEG 2 Layer III
Input Mode: Mono
Input S.Rate: 22KHz
Input B.Rate: 32kbps
Input File: input1
Output format: MPEG 1 Layer II
Output Mode: Mono
Output S.Rate: 44KHz
Output B.Rate: 32kbps
Output File: output1
Assuming all files are in the BESWEET.EXE folder what would be the syntax for this conversion? Note the drop from MPEG 2 to MPEG 1 and the layer change from III to II. Also the sample rate needs to change from 22 to 44 KHz.
Here is the closest I can get but it does not work.
BeSweet.exe -core( -input input1 -output output1 ) -toolame( -m m -b 32 -e )
Results 1 to 1 of 1
Are my audio commands are right?
By php111 in forum AudioReplies: 0Last Post: 13th Mar 2010, 12:11 -
Commands-how to resume a different VTS?
By MrMoody in forum Authoring (DVD)Replies: 7Last Post: 28th Apr 2009, 12:04 -
DVD VM Commands
By TonitoDJ in forum Authoring (DVD)Replies: 1Last Post: 24th Nov 2008, 09:55 -
Question about certain dos commands
By jimdagys in forum ComputerReplies: 35Last Post: 15th Oct 2008, 22:57 -
Following cell commands
By levick in forum Authoring (DVD)Replies: 1Last Post: 21st Aug 2007, 21:57
