I currently use Movie Factory2 and just recently downloaded the trail version Movie Factory 3 disc creator
I think this software is much better than version 2 with tons more features; Audio normalize, AC3, more video editing features, add player during burn, DVR support, motion menus, improved slideshow options, PPT files.......
Version3 and Version2 comparison Link:
http://www.ulead.com/dmf/compare2.htm
Things that I had problems with.
1. Relink feature is still not automated (deosn't do its own search) and if you have a large project file you will be stuck in the re-link loop and no way to cancel. (CTL-Alt-Del)
2. Where are the slidshow Audio fade in/out buttons like they have in Pictureshow2? The slideshow interface is now like PictureShow2 but missing Audio fade and multiple audio???
3. The menu background music will reset when the menu motion video ends at its 10, 20 or 30sec interval. The background menu video should reset and the seperate background music conitnue to play.
I will buy the version 3 upgrade if the slideshows have the Audio fade / multiple Audio additions for slideshows.
Amazing that the Chinese people at Ulead are more literate
in English than some Americans. -
It should be noted the comparison link above doesn't compare the BASIC MovieFactory 3 ($50) to MovieFactory 2.
It compares the souped-up $100 MovieFactory 3 Disc Creator to MovieFactory 2.
The basic MovieFactory 3 is missing a lot of the features found in the MovieFactory 3 Disc Creator.
Ulead Moviefactory 6 transition Help
By musickerns in forum Newbie / General discussionsReplies: 2Last Post: 18th Jun 2011, 14:26 -
Ulead Moviefactory
By acw in forum Newbie / General discussionsReplies: 10Last Post: 24th May 2009, 01:51 -
Ulead MovieFactory 6 Menu problems
By cheeseandcrackers in forum Authoring (DVD)Replies: 7Last Post: 18th Jan 2009, 01:59 -
Ulead DVD Moviefactory 5
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2007, 11:43 -
Questions about Ulead DVD MovieFactory 6
By cheeseandcrackers in forum Authoring (DVD)Replies: 5Last Post: 18th Jun 2007, 11:46
