Hope someone knows how to do this. I bought some anime vcds but want to use a smoother to make it look better but don't want to re-encode and lose quality. Cany anyone tell me how to do this. I've ripped the DAT file and the mpeg from the vcd so I have both available to process them. Thanks.
Results 1 to 10 of 10
Simply not possible, you have to re-encode.Originally Posted by perdomot"Art is making something out of nothing and selling it." - Frank Zappa
I was afraid of that. The movies come encoded with standard vcd settings but I use XVCD settings to get better results. If I encode at a higher bit rate, do you think that would help?
Probably not -- you cannot have anything better than your source. Most relayable answer - try a small portion on a CD-RW.Originally Posted by perdomot
I've had some luck recoding VCD/MPEG1 to low compression, low distortion XviD AVIs with VirtualDub, using it's temporal smoother filter set to about a 4 level, then re-encoding to MPEG1. The temporal smoother seems to blend out the mpeg blockieness and preserve the edges, while reducing the horizontal/vertical line jittering and diagonal jaggies. The only downside is there is a slight ghost effect when there's an even light or dark colored background and an opposite shade object moves rapidly across it. I usually don't notice it unless I know to look for it.
Rather than compressing the video (to xvid or whatever) it's best to leave the video as uncompressed and frameserve directly from Vdub to your encoder. No large intermediate file and no compression loss. Here's a guide. 8)Originally Posted by CrustyCurmudgeon"Art is making something out of nothing and selling it." - Frank Zappa
On short clips I use HuffYUV, but since I have Win98 and FAT32 won't allow files larger than 4 gig, I have to use more compression than HuffYUV can be counted on for clips longer than about 15 minutes. That link to using VirtualDub as a frame server didn't seem to me to offer a solution... plus it looked pretty complicated. Is is the right link?
EDIT - Oops. I see how it is used with TMPGEnd to do the job... neat, though still a bit complicated, but I can see how that would be better for longer stuff. -
Once you have it set up for frameserving, which you only do once, it's a piece of cake. Give it a try!Originally Posted by CrustyCurmudgeon
"Art is making something out of nothing and selling it." - Frank Zappa -
You're welcome.
What is the best way to treat Telecine before Temporal Smoothing?
By unclescoob in forum RestorationReplies: 97Last Post: 28th Feb 2012, 14:18 -
Temporal smoothing before/after shrinking frame?
By Gew in forum EditingReplies: 23Last Post: 28th Sep 2009, 19:26 -
Smoothing zooms in an editor
By SCDVD in forum EditingReplies: 2Last Post: 2nd Jul 2008, 18:54 -
VobSub smoothing method
By Digiface in forum SubtitleReplies: 0Last Post: 24th May 2007, 07:55
