My DVD writer Aopen 4410 can't read the DVD+R discs I've just burned. It can read the DVD+R discs I burned for some weeks ago. The discs I'm burning nowadays are the same kind and I use the same settings, but the DVD-ROM in my old computer can read them so they should be fine. Why can't my DVD writer read them?
If I burn DVD+RW (Philips discs) my DVD writer can read them perfectly.
Equipment
Program: RecordMAX
Burner: Aopen 4410
Discs: Philips DVD+R CMC and DVD+RW CMC
* On Aopen's homepage they listed Philips discs as compatible.
Could be the Discs. Try a different media thats not as "cheap".
Adam
DVD Decrypter>DVDShrink>CopyToDVD -
Try using DvdInfoPro to compare the settings on the disks that work with those that don't work. Could be that something needs to be changed in the bitsettings.
BAD DISC BURNT WITH DVDDECRYPTER
Region information N/A not a DVD-VIDEO
Media code/Manufacturer ID CMC MAG F01
Format Capacity Not Formatted
Book Type DVD-ROM
Media Type DVD+R
Default DVD+R book type DVD+R
Media Id Code Speed 2.4x 3324KBps
Data area starting sector 30000h
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1
BAD DISC BURNT WITH RECORDNOW MAX
Book Type DVD-R
Media Type DVD+R
Available Write Descriptor CLV 4.0x 5540KBps
Number of Layers 1
Book Type DVD+R
Media Type DVD+R
Linear Density Blank Disc
Track Density Unknown
Number of Layers 1
Book Type DVD+R
Media Type DVD+R
Number of Layers 1
GOOD DISC BURNT WITH RECORDNOW MAX
Format Type UDF 1.02
Volume Name Filmer
Application id
Implementation id Prassi
Recording Date/Time (mm/dd/yyyy) 12/27/2003 12:22:22
Format Capacity 4.35GB(4.67GB)
Book Type DVD+R
Media Type DVD+R
Data area end sector 22CEBFh
Number of Layers 1
Volume Name Erik
Application id
Recording Date/Time (mm/dd/yyyy) 12/27/2003 14:27:22
Format Capacity 4.37GB(4.70GB)
Book Type DVD+R
Media Type DVD+R
Data area end sector 22FC7Fh
Number of Layers 1
Dvdinfopro finds this disc much faster than the other bad ones.
Format Capacity 4.38GB(4.70GB)
Book Type DVD+R
Media Type DVD+R
Data area end sector 23053Fh
Number of Layers 1 -
Are these DVD movies?
They just don't look like DVD movies.
( "NOT FORMATTED" , "NOT A DVD VIDEO")
CMC's are not the best ones
Get RICOHJPNR medias -
Some of them are videos and some are data discs. I now that CMC are not the best ones but according to Aopen these philips dvd+r should be fine. I've bought 25 philips dvd+r 4x. I don't to throw them away.
Verbatim DVD+R #96526 100 pk purple label WARNING - reads CMC M01
By xctrekker in forum MediaReplies: 11Last Post: 15th Apr 2012, 17:17 -
Dell with a NEC 2100AD DVD+R writer - flash update to write to DVD-R?
By DirtBikeMike in forum ComputerReplies: 5Last Post: 30th Sep 2010, 11:24 -
DVD Rom reads DVD but won't play DVD
By cougaris in forum DVD & Blu-ray PlayersReplies: 2Last Post: 27th Jul 2008, 21:58 -
Dvd Burner only reads older dvds, won't read newer ones all the sudden??
By kpaxfaq in forum DVD & Blu-ray WritersReplies: 6Last Post: 28th Feb 2008, 14:11 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59
