Hi,
I've been following Doom9's DVD9 to two DVD5 guide using IfoEdit. After I've output all the files per the guide's instructions, I use my Nero 5.5.10.54 to burn. I selected the DVD Video mode, and dumped all the files created in one disk into the video_ts folder. However, when I was ready to burn, Nero gave me several warning messages about how the files weren't conforming to the DVD Video standard, and asked whether I still want to continue with the burning. Since I was only testing on a DVD-RW, I said yes with the burn. The resulting DVD seemed to play just fine in PowerDVD, but I haven't tested it in a stand-alone machine yet. Has anyone else encountered those messages? Or Nero should have burned without questions and I must have done something wrong?
Thanks in advance...
Spiffy
I think the MPEG-2 files may not have been compliant. What were their specs exactly?
Hello. -
These are files directly from the original disc though -- so I'm not sure why the files would not comply to the mpeg 2 standard.
I just popped the test DVD-RW disk into a stand alone player, and it played fine....
This is the screenshot of the first error message:
Would the fact that I used a network drive to store the IfoEdit output files cause the error messages? -
I doubt it. I still am looking for the file specs, though.
Hello. -
What exactly do you mean by file specs?
After I posted the question, I did more research, and found a whole bunch of discussions concerning Reallocation Errors when splitting DVD9 to two DVD5s. But none of the fixes solve the problem...
Error messages burning data DVD using Nero version 6
By craigsb in forum ComputerReplies: 6Last Post: 27th Oct 2011, 09:12 -
Help with simultaneous video outputs
By Rob #3 in forum Media Center PC / MediaCentersReplies: 0Last Post: 7th May 2010, 21:53 -
Winavi warning messages
By hrpskyrunner in forum Video ConversionReplies: 0Last Post: 22nd Mar 2009, 15:33 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Activating PC- DV outputs
By 1234567 in forum DVB / IPTVReplies: 13Last Post: 19th Feb 2008, 17:43
