Using the facility in preferences I'm setting a maximum target output size of 4150mb, I don't like to fill a DVD-r.
When I go to click backup I'm getting an error that the contents will be too big, something I don't get if I don't pre-select the final target output size and simple use the standard setting, ie 4464mb
I've done a dummy run and the final size is as I set, 4150mb-ish.
Anyone else getting this message, is it something I'm doing?
Will
tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Hi Will.
If you lower the target size, DVD Shrink will obviously have to apply more compression to reach it.
If you leave the target size at its default setting, less compression will be required.
DVD Shrink has a limitation to the amount of compression it can apply.
My guess would be you reached this limit.
Solutions:
- Make sure you deleted all the uneccessary audio/subpicture streams.
- If you're using "Full-Disk", try "Re-author" to do a movie-only or movie+extras backup.
- Shrink the DVD twice (shrink the "shrunk" files). -
This, and the rest of your message seems to have got through to my aging brain.Originally Posted by ddlooping
Thanks,
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
No problem.
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
XVID4PSP and target file size issue,
By bugsboney in forum Video ConversionReplies: 4Last Post: 11th Nov 2009, 17:24 -
ffmpeg.exe - Target file size?
By Gew in forum Video ConversionReplies: 0Last Post: 25th Feb 2009, 13:46 -
can i fix the target file size in convertxtodvd?
By sumeshkri in forum Video ConversionReplies: 3Last Post: 31st Oct 2008, 01:59 -
ffmepg: aquiring target file size
By raschko in forum Video ConversionReplies: 2Last Post: 19th Nov 2007, 16:46
