Here's information on two medias, first does not work, the second does.
Media Information
Disc Regions are 1,2,3,4,5,6,7,8
Media code/Manufacturer ID RICOHJPNR01
Format Type UDF 1.02
Volume Name NEW
Application id
Implementation id AHEAD Nero
Recording Date/Time (mm/dd/yyyy) 1/12/2004 13:30:46
Format Capacity 2.18GB(2.35GB)
Book Type DVD+R
Media Type DVD+R
Media Id Code Speed 4.0x 5540KBps
Available Write Descriptor CLV 4.0x 5540KBps
Available Write Descriptor CLV 2.4x 3324KBps
Data area starting sector 30000h
Data area end sector 117AAFh
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1
The above disc does not play on my standalone player, however
the disc below will play.
Media Information
Volume Name
Application id
Implementation id roxio EasyCDCreator
Recording Date/Time (mm/dd/yyyy) 10/10/2003 2:28:01
Format Capacity 4.01GB(4.31GB)
Book Type DVD-ROM
Media Type DVD+R
Data area end sector 20137Fh
Number of Layers 1
I only have Nero, so I can't use Roxio. The above disc works on my player.
Now how do I burn with the dvd-rom booktype ? when using Nero :S
I'm trying to burn dvd-video. Iso/udf mode ? or.....
Sorry if this gets asked often, I think this is the reason
why my standalone does not play the +R disc I burned and
playes the few +R's I got (all have dvd-rom booktype)
from other folks.
Could anyone confirm my suspicions and tell me how
to get the booktype right.
Another dvd-burning newbie![]()
Baldrick just added this - might help
https://www.videohelp.com/glossary#bitsetting -
Argh..so no chance to change
the booktype with my LG multi-burner then
Oh well, atleast -R works on my standalone (and
a new that plays +R booktype should not cost too much)
dvd player wont play AVI or dvd video burned discs
By rockerman in forum Authoring (DVD)Replies: 5Last Post: 20th Oct 2011, 14:01 -
I have an Aopen Dvd Burner, how can I set booktype in imgburn?
By frieday in forum Authoring (DVD)Replies: 13Last Post: 3rd Nov 2009, 06:30 -
Hybrid disc with both DVD-Video & DVD-ROM - is it possible to burn?
By rjamesd05 in forum Authoring (DVD)Replies: 5Last Post: 18th Sep 2009, 14:07 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 21:44 -
Mpeg Video Wizard DVD: Burned to DVD-R, Plays back with hiccups.
By Giovannini in forum Newbie / General discussionsReplies: 13Last Post: 27th May 2007, 06:54
