I'm pretty much setup hardware and software wise. Just waiting for my JVC HRS-9800 (should be here today). So is this pretty much how it goes from here.
1. Capture VHS to AVI (or MJPEG)
2. Encode to MPEG-2
3. Author
4. Burn
5. Check it out on the TV and see what I want to change
6. Go back to step 1 and make this pass with some changes
OR ... if I capture right to MPEG-2
1. Capture VHS to MPEG-2
2. Author
3. Burn
4. Check it out on the TV and see what I want to change
5. Go back to step 1 and make this pass with some changes
When you guys are burning and checking out the result do you use
DVD-RW so you can re-write without having to use another DVD
or is it important that you use the mdiea that your output will finally be on.
Thanks again .... MACKY
That is an -excellent- habit to get into. If you run into a technique that doesn't work for you, you can blow a lot of money on coasters in a very short time. RW lets you tweak and fiddle without burning up the rent money every time you try a new idea. Also, if you haven't already, check out Lord Smurf's page. He's done an astonishing amount of work on VHS capture. Definitely worth a read.Originally Posted by MACKYFight spammers ghetto kung-fu style! Join the Unsolicited Commandos! or the Spam Vampires!
No, use dvd-rw's, they're fine for testing.
I don't have that facility, my burner is a DVD-R/Ram but I'm at a stage where where final ouput is my final output.
Your biggest challenge is determining the perfect settings in
a) capture and
b) encoding
If you use TMPGEnc Plus for your avi to mpeg2 stage there's a great guide on this site, I'll dig out the link if you're interested.
Will
Or MJPEG?Capture VHS to AVI (or MJPEG)
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
DVD encode settings help pretty please
By supportpartners in forum ffmpegX general discussionReplies: 6Last Post: 11th Nov 2011, 05:42 -
BD Rebiulder Pretty Smart
By wulf109 in forum Blu-ray RippingReplies: 2Last Post: 27th Jan 2010, 17:07 -
OS X Issue - converting DVD to, well, pretty much anything!
By phelan74 in forum DVD RippingReplies: 0Last Post: 18th Jan 2009, 23:09 -
Screenflow looks pretty good to me...anyone use it?
By Antoniola in forum MacReplies: 2Last Post: 22nd Sep 2008, 15:40 -
Any video player that plays pretty much everything?
By WitchfinderGeneral in forum Newbie / General discussionsReplies: 5Last Post: 13th Jun 2007, 20:12
