I have a 6.8 gig RAR file. I want to place it on DVD. What is best program for Spliting and then burning this file?
If it isn't video related post in the other sections(computer or off topic). I'm moving your topic.
You can always unrar it and rar it up yourself - it'll give you the option of how large you want to make the files. You can pick 4 gigs or whatever if you'd like. If you're going to put it on 2 dvds, your best bet is to pick store (no compression) because otherwise it's going to take a long time to compress/uncompress when it's not necessary.
Where do you get the Option to Make size you want? I found 1 place but It had like 1.4 meg,600 meg(CD) and few other ones. I have WinRAR 3.10 Beta 4. Do I need a newer version for the DVD size files?
Thanks -
There should be a section "custom" if you still can't find it why don't you use 600mb and just put 7 sections on the first dvd and the rest on a second.
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 17:03 -
Burn 3 DVDs at a time
By Dimava in forum DVD & Blu-ray WritersReplies: 42Last Post: 5th Aug 2008, 16:31 -
How do i burn Lightscribe DVDs?
By Bully9 in forum Newbie / General discussionsReplies: 14Last Post: 12th Nov 2007, 16:56 -
trying to burn dvds
By steelercanes83 in forum Authoring (DVD)Replies: 1Last Post: 15th Oct 2007, 21:59
