I bought a Sony Dru510 dvd burner updated all the firmware its all up to date and new, and i'm using Maxwll DVD-R's. I have two mpg files (used for vcds) I created DVD Files for them using TMPEG DVD Author and when I burned it to the dvd it runs but the sound doesnt match, its about a 5 sec diference do I have to do something to the mpg files? and if so can you explain what and what progs I should use? Thanks!
First, you'll need to figure out where the out of sync issue began. Check the original source, check the converted to MPEG file. See where this began. After we know this we can get more specific on where and what to change.
I didnt convert the file to anything, I just took the mpg files and made them into the dvd files with TMEPG DVD Author and then i burned them with NTI Dvd Maker and its not in sync should I rip the audio from the orignal mpg files and do it like that and if so what prog should I use because Virtual Dub wont load the files
Newbie Question on Burning Bluray
By discover in forum Newbie / General discussionsReplies: 5Last Post: 23rd Feb 2012, 14:35 -
Newbie question RE: burning DVDs from HD camcorder
By lcinva in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 12th Sep 2011, 08:53 -
Newbie: Need help burning movies into DVD
By silveraden in forum Newbie / General discussionsReplies: 3Last Post: 29th Nov 2010, 11:36 -
total newbie dvd converting burning
By mujin in forum Newbie / General discussionsReplies: 6Last Post: 29th Jan 2009, 11:28 -
Newbie Roxio easy cd and dvd burning question.
By mmmipa in forum Newbie / General discussionsReplies: 8Last Post: 24th Nov 2007, 21:31
