    Dec 2003
    Vietnam
    Sorry for my poor English
    I meet a problem in writing DVD data by Nero I lost a lot of blank DVD because of this problem ,now I 'm in a big trouble ,please help me solve it
    I'll appreciate your help ,I must write DVDs data but now I can't do anything
    I downloaded ASPI drivers 4.71.2 but I can't install correctlly so Nero info tool give s message say that system ASPI installation is corrupted
    This is the log file
    Windows XP 5.1
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 10:03:20 AM
    ahead WinASPI: File 'J:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 1/16/2004 10:41:24 AM
    Nero version: 6.3.0.2
    Recorder: <DVD DUAL GO-W0404A> Version: 0039 - HA 1 TA 1 - 6.3.0.2
    Adapter driver: <atapi> HA 1
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ATAPI
    CD-ROM: <ASUS DVD-ROM E616 >Version: Z.0 - HA 1 TA 0 - 6.3.0.2
    === Scsi-Device-Map ===
    DiskPeripheral : ST340810A atapi Port 0 ID 0 DMA: On
    DiskPeripheral : ST3120022A atapi Port 0 ID 1 DMA: On
    CdRomPeripheral : ASUS DVD-ROM E616 atapi Port 1 ID 0 DMA: Off
    CdRomPeripheral : DVD DUAL GO-W0404A atapi Port 1 ID 1 DMA: On
    CdRomPeripheral : Generic DVD-ROM 1.0 d344prt Port 2 ID 0 DMA: Off
    === CDRom-Device-Map ===
    ASUS DVD-ROM E616 H: CDRom0
    DVD DUAL GO-W0404A I: CDRom1
    Generic DVD-ROM D: CDRom2
    AutoRun : 1
    Excluded drive IDs:
    CmdQueuing : 1
    CmdNotification: 2
    WriteBufferSize: 39845888 (0) Byte
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Physical memory : 247MB (253424kB)
    Free physical memory: 91MB (93252kB)
    Memory in use : 63 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    17.1.2004
    ISO compilation
    6:03:47 PM #1 Text 0 File Isodoc.cpp, Line 6029
    Iso document burn settings
    Determine maximum speed : FALSE
    Simulate : TRUE
    Write : TRUE
    Finalize CD : FALSE
    Multisession : TRUE
    Multisession type: : Start multisession
    Burning mode : DAO
    Mode : 1
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Character set : ISO 9660
    Joliet : TRUE
    Allow pathdepth more than 8 directories : TRUE
    Allow more than 255 characters in path : TRUE
    Write ISO9660 ;1 file extensions : TRUE
    6:03:47 PM #2 Text 0 File Reader.cpp, Line 118
    Reader running
    6:03:47 PM #3 Text 0 File Writer.cpp, Line 124
    Writer DVD DUAL GO-W0404A running
    6:03:47 PM #4 ISO9660GEN -11 File geniso.cpp, Line 3882
    First writeable address = 0 (0x00000000)
    6:03:47 PM #5 Text 0 File Burncd.cpp, Line 3101
    Turn on Disc-at-once, using DVD media
    6:03:51 PM #6 Text 0 File DlgWaitCD.cpp, Line 240
    Last possible write address on media: 2298495 (510:46.45, 4489MB)
    Last address to be written: 2094847 (465:31.22, 4091MB)
    6:03:51 PM #7 Text 0 File DlgWaitCD.cpp, Line 245
    Write in overburning mode: FALSE
    6:03:51 PM #8 Text 0 File DlgWaitCD.cpp, Line 2085
    Recorder: DVD DUAL GO-W0404A, Media type: DVD-R
    Disc Manufacturer: AN31 -
    Disc Application Code: 64, Disc Physical Code: 193
    6:03:51 PM #9 Text 0 File DlgWaitCD.cpp, Line 406
    >>> Protocol of DlgWaitCD activities: <<<
    6:03:51 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 779
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 (CTransferItem)
    2 indices, index0 (150) not provided
    original disc pos #0 + 2094848 (2094848) = #2094848/465:31.23
    relocatable, disc pos for caching/writing not required/required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2094848 blocks [DVD DUAL GO-W0404A ]
    6:03:52 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 948
    Prepare recorder [DVD DUAL GO-W0404A ] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc not fixated
    Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4290248704, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
    0 | lead-in | 0 | 0x00 | 0x41
    0 | 1 | 0 | 0x00 | 0x41
    0 | 1 | 1 | 0x00 | 0x41
    2094848 | lead-out | 1 | 0x00 | 0x41
    6:03:53 PM #12 Phase 24 File dlgbrnst.cpp, Line 1800
    Caching of files started
    6:03:53 PM #13 Text 0 File Burncd.cpp, Line 4073
    Cache writing successful.
    6:03:53 PM #14 Phase 25 File dlgbrnst.cpp, Line 1800
    Caching of files completed
    6:03:53 PM #15 Phase 32 File dlgbrnst.cpp, Line 1800
    Simulation started at 2x (2,760 KB/s)
    6:03:54 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2264
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    6:03:55 PM #17 Text 0 File dlgbrnst.cpp, Line 1658
    Set remaining time: 13:01,225 (781225ms) -> OK
    6:03:55 PM #18 Text 0 File DVDR.cpp, Line 1512
    Recording mode: Sequential Recording Mode for Multisession
    6:03:55 PM #19 Text 0 File Mmc.cpp, Line 19451
    Set BUFE: JustLink -> ON
    6:03:55 PM #20 Text 0 File DVDR.cpp, Line 1643
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    6:03:55 PM #21 Text 0 File Cdrdrv.cpp, Line 7941
    ---- DVD Structure: Physical Format Information (00h) ----
    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD-R (2), Part Version: 5
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 0 h
    End Sector Number in Layer 0: 0 h
    Data in Burst Cutting Area (BCA) does not exist
    Media Specific:
    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    6:03:57 PM #22 Text 0 File Cdrdrv.cpp, Line 1277
    18:03:57.859 - DVD DUAL GO-W0404A\H1 T1 : Queue again later
    6:29:42 PM #23 Text 0 File WriterStatus.cpp, Line 115
    <DVD DUAL GO-W0404A > start writing Lead-Out at LBA 2094848 (1FF700h), lenght 0 blocks
    6:29:42 PM #24 Text 0 File ThreadedTransfer.cpp, Line 229
    all writers idle, stopping conversion
    6:29:42 PM #25 Text 0 File DVDR.cpp, Line 1847
    EndDAO: Last written address was 2094847
    6:29:56 PM #26 Text 0 File dlgbrnst.cpp, Line 1658
    Set remaining time: 0:00,000 (0ms) -> OK
    6:29:56 PM #27 Text 0 File dlgbrnst.cpp, Line 1658
    6:29:56 PM #28 Phase 33 File dlgbrnst.cpp, Line 1800
    Simulation completed successfully at 2x (2,760 KB/s)
    6:29:57 PM #29 Phase 36 File dlgbrnst.cpp, Line 1800
    Burn process started at 2x (2,760 KB/s)
    6:29:58 PM #30 Text 0 File ThreadedTransferInterface.cpp, Line 2264
    6:29:58 PM #31 Text 0 File dlgbrnst.cpp, Line 1658
    6:29:59 PM #32 Text 0 File DVDR.cpp, Line 1512
    6:29:59 PM #33 Text 0 File Mmc.cpp, Line 19451
    6:29:59 PM #34 Text 0 File DVDR.cpp, Line 1643
    6:29:59 PM #35 Text 0 File Cdrdrv.cpp, Line 7941
    Media Specific:
    6:30:23 PM #36 Text 0 File Cdrdrv.cpp, Line 1277
    18:30:23.937 - DVD DUAL GO-W0404A\H1 T1 : Queue again later
    6:56:08 PM #37 Text 0 File WriterStatus.cpp, Line 115
    6:56:08 PM #38 Text 0 File ThreadedTransfer.cpp, Line 229
    6:56:08 PM #39 Text 0 File DVDR.cpp, Line 1847
    6:56:11 PM #40 Phase 133 File dlgbrnst.cpp, Line 1800
    Writing short lead-out
    6:57:00 PM #41 SCSI -1135 File Cdrdrv.cpp, Line 1171
    SCSI Exec, HA 1, TA 1, LUN 0
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x0C
    Sense Qual: 0x00
    CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
    0x00 0x00 0x00 0x00 0x0C 0x00
    6:57:00 PM #42 Text 0 File dlgbrnst.cpp, Line 1658
    6:57:00 PM #43 CDR -1135 File ThreadedTransferInterface.cpp, Line 1659
    Write error
    6:57:00 PM #44 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1659
    Could not perform end of Disc-at-once
    6:57:00 PM #45 Text 0 File DVDR.cpp, Line 1847
    EndDAO: Last written address was -1
    6:57:00 PM #46 Text 0 File dlgbrnst.cpp, Line 1658
    6:57:00 PM #47 Text 0 File dlgbrnst.cpp, Line 1658
    6:57:00 PM #48 Phase 38 File dlgbrnst.cpp, Line 1800
    Burn process failed at 2x (2,760 KB/s)
    Existing drivers:
    File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 7/17/2002 9:05:10 AM
    File 'Drivers\PXHELP20.SYS': Ver=2.02.60a, size=17232 bytes, created 8/27/2003 2:02:00 AM (Prassi/Veritas driver for win 2K)
    File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 8/29/2002 1:27:50 AM (Adapter driver for rec)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
  2. Thats is a lot of shit :/, I can't actually figure why you installed the aspi drivers when Nero comes with its own aspi drivers...
    10110101100111012011 <- The bug Bill doesn't talk about.
    Dec 2003
    Vietnam
    After I install Force ASPI Nero info tool say that both system ASPI and Nero ASPI are working properly
    It's very strange that I burned 3 DVD data sucessfully but the fourth is failed .I wonder if DVD writer can't work constantly over 2 hours ,this is the new log file
    I can't understand why ,please tell me what to do ,stimulation is sucessfull but when I burn "real" DVD ,I meet a message "Could not perform end of disc at once "
    Windows XP 5.1
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 9/10/1999 12:06:00 PM
    Nero version: 6.3.0.2 (Nero Express)
    AutoRun : 1
    Excluded drive IDs:
    CmdQueuing : 1
    CmdNotification: 2
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Free physical memory: 84MB (86724kB)
    Memory in use : 65 %
    Use Inquiry : 1
    18.1.2004
    ISO compilation
    11:01:32 AM #1 Text 0 File Isodoc.cpp, Line 6029
    Simulate : FALSE
    Write : TRUE
    Finalize CD : FALSE
    Multisession : TRUE
    Burning mode : DAO
    Mode : 1
    Joliet : TRUE
    11:01:32 AM #2 Text 0 File Reader.cpp, Line 118
    Reader running
    11:01:32 AM #3 Text 0 File Writer.cpp, Line 124
    11:01:32 AM #4 ISO9660GEN -11 File geniso.cpp, Line 3882
    11:01:32 AM #5 Text 0 File Burncd.cpp, Line 3101
    11:01:36 AM #6 Text 0 File DlgWaitCD.cpp, Line 240
    Last address to be written: 2138703 (475:16.03, 4177MB)
    11:01:36 AM #7 Text 0 File DlgWaitCD.cpp, Line 245
    11:01:36 AM #8 Text 0 File DlgWaitCD.cpp, Line 2085
    11:01:36 AM #9 Text 0 File DlgWaitCD.cpp, Line 406
    11:01:36 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 779
    original disc pos #0 + 2138704 (2138704) = #2138704/475:16.4
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2138704 blocks [DVD DUAL GO-W0404A ]
    11:01:37 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 948
    DAO infos:
    MCN: ""
    Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4380065792, ISRC ""
    DAO layout:
    2138704 | lead-out | 1 | 0x00 | 0x41
    11:01:38 AM #12 Phase 24 File dlgbrnst.cpp, Line 1800
    11:01:38 AM #13 Text 0 File Burncd.cpp, Line 4073
    11:01:38 AM #14 Phase 25 File dlgbrnst.cpp, Line 1800
    11:01:38 AM #15 Phase 36 File dlgbrnst.cpp, Line 1800
    11:01:39 AM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2264
    11:01:39 AM #17 Text 0 File dlgbrnst.cpp, Line 1658
    Set remaining time: 52:53,231 (3173231ms) -> OK
    11:01:39 AM #18 Text 0 File DVDR.cpp, Line 1512
    11:01:39 AM #19 Text 0 File Mmc.cpp, Line 19451
    11:01:40 AM #20 Text 0 File DVDR.cpp, Line 1643
    11:01:40 AM #21 Text 0 File Cdrdrv.cpp, Line 7941
    Media Specific:
    11:02:03 AM #22 Text 0 File Cdrdrv.cpp, Line 1277
    11:02:03.781 - DVD DUAL GO-W0404A\H1 T1 : Queue again later
    11:28:20 AM #23 Text 0 File WriterStatus.cpp, Line 115
    <DVD DUAL GO-W0404A > start writing Lead-Out at LBA 2138704 (20A250h), lenght 0 blocks
    11:28:20 AM #24 Text 0 File ThreadedTransfer.cpp, Line 229
    11:28:21 AM #25 Text 0 File DVDR.cpp, Line 1847
    EndDAO: Last written address was 2138703
    11:28:24 AM #26 Phase 133 File dlgbrnst.cpp, Line 1800
    11:28:41 AM #27 SCSI -1135 File Cdrdrv.cpp, Line 1171
    Sense Code: 0x0C
    Sense Qual: 0x00
    11:28:41 AM #28 Text 0 File dlgbrnst.cpp, Line 1658
    11:28:41 AM #29 CDR -1135 File ThreadedTransferInterface.cpp, Line 1659
    Write error
    11:28:41 AM #30 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1659
    11:28:41 AM #31 Text 0 File DVDR.cpp, Line 1847
    11:28:41 AM #32 Text 0 File dlgbrnst.cpp, Line 1658
    11:28:41 AM #33 Text 0 File dlgbrnst.cpp, Line 1658
    11:28:41 AM #34 Phase 38 File dlgbrnst.cpp, Line 1800
    Existing drivers:
    File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 9/10/1999 12:06:00 PM
    Registry Keys:
    Dec 2003
    Vietnam
    I restart computer and I can burn fifth DVD sucessfull but I still worry about burning over 3 DVDs constantly
    Is my problem very diffucult ?I need help very much and I look forward to hear anything about solution
    My PC is P4 1.5 G and 248 MB DDR ,is it weak for burning DVD ?.I can burn CDs normally .
    Oct 2003
    deep in Wonderland.
    It sounds like your drive might be overheating. The rebooting process is probably giving the drive time to cool down and that's why the next burn works.
    Try burning one or two discs, then wait a half-hour or so and start again. If it works, then it's probably a thermal problem.
    Fight spammers ghetto kung-fu style! Join the Unsolicited Commandos! or the Spam Vampires!
  6. It sounds like your drive might be overheating. The rebooting process is probably giving the drive time to cool down and that's why the next burn works.
    I agree as I had this problem about 3 months ago and it turned out to be the fact that I had a HDD installed just below it and the heat generated was causing errors in the burner. I moved the burner to another mounting where it had no heat generating equipment either above or below and BINGO it worked just fine.
    Artificial intelligence is no match for natural stupidity.
