Results 1 to 11 of 11
  1. Hi all,
    I have a bunch of DVD compliant mpeg2 files that I need to edit (add transitions, effects, music etc). I know it's not a good idea to edit converted mpeg as opposed to the source files but I no longer have the original dv avi files.
    Ideally, I'm looking for a video editor that will do the least amount of "damage" to the mpeg files, i.e by re-encoding etc. Any suggestions?
    Thanks in advance for any replies.
    DF
    Apr 2002
    The State of Frustration
    I believe Video Studio can do your project justice, just remember to set the quality in Project settings to 100%.
    Hello.
  3. Thanks for the reply. Just one question: Won't VS try to re-encode using its own encoder after the editing is finished? Or is that unavoidable with any editor when you try to edit mpeg files?
    Thanks again,
    DF
    Apr 2002
    Since you want to add transitions and effects, I really do not see any other way. I hope I'm wrong. Gurus can he add transitions and effects to an exisiting MPEG video without re-encoding?
    Hello.
  5. Member SaSi's Avatar
    Jan 2003
    Hellas
    I recommend you try Honestech's MPEG editor and Mainconcept's EVE editor. Both come with trial versions.
    They both claim that the editor won't re-encode when it doesn't have to do so. So, if you just trim the video it saves the output files without re-encoding each frame. When you do transitions, they re-encode the frames participating in the transitions.
    I tried EVE a bit and the speed of processing indicates it's not re-encoding.
    The more I learn, the more I come to realize how little it is I know.
  6. - Ulead VideoStudio...
    http://www.ulead.com/vs/runme.htm
    - Ulead MediaStudio Pro...
    http://www.ulead.com/msp/runme.htm
    - Ulead DVD MovieFactory 3.0...
    http://www.ulead.com/dmf/runme.htm
    All of the above use Smart Render technology for MPEG editing.
    This means video changed by titles, transitions, filters will be re-encoded precisely where those titles, transitions, filters "touch" the original video.
    The portions of video not touched by titles, transitions, filters does not undergo re-encoding.
    All of this - of course - requires the user to precisely adjust his or her project settings to precisely match the properties of the source video/audio.
    Jerry Jones
    http://www.jonesgroup.net
    Thanks again,
    DF
  7. Thanks to everyone for all the tips. I have Vegas 4 so I'll start with that, then give VS7 a try. Thanks again.
  8. Sasi / Specialist:
    The programs both of you mentioned are exactly what I have been looking for. I'm trying to make a DVD mix, and the only editing I have been wanting to do is fade in/out of each clip; however I did not want to lose any quality. For the time being I was cutting about 10 sec. from the beginning & end of each clip, adding fades to those clips, and then joining the clip back to original.
    Sasi:
    I tried the EVE 1.2 program. Seems cool, but I must be missing something. From the looks of it, the program slices the video file at the points that have edits, then it only has to re-encode those "indivdual" files, then merges them with the original (sort of like what I desribed I was doing up above...only on the fly & a hell of a lot faster). But when I go to produce my project, I render it, and it goes through the whole file (takes awhile) and ouputs a .mpg file (i was working with a .m2v) that is compressed (about 203 megs compared to the original's 236). The original file, .m2v, had a bitrate of 9.8, and the ouputted .mpg was at 8. How do I get this program to only render the parts that need it?
  9. Member SaSi's Avatar
    Jan 2003
    Hellas
    I haven't done a full project with EVE. Just played around with it after getting their encoder.
    I have read the manual though and I vaguely remember about options for outputing the file that will not force a re-encode. Have you looked at any settings and options for output?
  10. There's very little options to mess with. Maybe it is because I am using a demo version? I don't know.
  11. Member ticos2000's Avatar
    May 2001
    bogota colombia southamer
    best tool to do that is veges video 4 you can even processed your mp3s as part of the mpeg 2 file., tons of transitions and quality is great, I usually make the moving backgrounds to put on the dvd root menu...looks really fancy
