Results 1 to 12 of 12
  1. I've seen the panny dmr-hs2 and I know if does not, only 1 component output. Just composit and s-video for input
    Does anyone know if any of the newer modles have component input for better quality recording?
    Apr 2002
    The State of Frustration
    I think if you did a web search for "DVD recorder, component input", I think you will be pleasantly surprised.
    Hello.
    My APEX DRX-9000 does
  4. This one does http://www.target.com/gp/detail.html/ref=cm_reviews_dp_seemore/601-1674104-5676135?asi...Reviews&coliid
    I have one which I only use for recording from the satellite. The only downside to this recorder is it doesn't have progressive playback but then I would never use a DVD recorder as a player, for that I have this fine DVI enabled player so I watch my DVD's at 720p or 1080i . http://www.vinc.com/product.asp?id=31&PID=21
  5. Or check my list for couple of recorders.
  6. Originally Posted by lordsmurf
    Are you sure about this ? Component Input ? Not output... Can you post picture ?
  7. Philips 985 has.
    Oops. Output. No input.
  9. Thanks for the help.
    Does anyone know if any of the panasonics or pioneers do?
    I was interested in them since they do dvd-r and the phillips do +R instead.
  10. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    There is a nice Pioneer unit that does. Also has a hard drive and option for 2 DVD-R drives. I forget the model number, but you can find it on their web site. Price was around $4000.00 USD and there is no tuner! Yes it is a broadcast level machine. I have one in the budget for next year at work, hope it passes.
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
  11. Member The village idiot's Avatar
    Apr 2002
    Here's a closeup of the back panel:
    and a link to the specs:
    http://www.pioneerelectronics.com/pna/product/detail/0,,2076_17573248_38303,00.html
    Jan 2004
    Bothell, Washington, USA
    The North American version of the Philips recorders (DVDR895, DVDR75/80 series) have component In and Out. Product brochures and user manuals are available from their Web site.
