  1. Can i get more info about this option "Run backup in low priority mode"
    If i check this box, does that mean it will produce poor quality than High Priority mode(unchecked)?
    or does this will produce in longer time because of low priority?
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Its a time thing. Use Low Priority if you want to use the PC for other stuff while it runs, it just takes alot longer.
  3. I'm a Super Moderator johns0's Avatar
    canada
    It just means it uses less processing power at the expense at letting other apps run without bogging things down and it slows down the process.
