How do I change the map color ( the color that appears on a button when highlited) in the trial version of dvd-lab or is this not possible? The help file said that there was a map tab under menu but I don't see one.
After you create your links on the menu, on the right hand side there is a tab labeled MAP. There are 3 sections NORMAL, ACTIVATED and SELECTED. Change the color and the sliders to whatever you want.
The trial version is fully functional so everything should work for 30 days. After that you will not even be ableto get into the program if you don't have the registration key. -
still can't find it. could you b more specific or better yet post a sreenshot. Do i have to be under menu, movie, what. i just cant find it.
How to change menu aspect ratio in DVD-Lab Pro ?
By V879 in forum Authoring (DVD)Replies: 2Last Post: 1st May 2011, 17:11 -
DVD-Lab Pro: Subtitles change text
By TheLaserdisc in forum Authoring (DVD)Replies: 8Last Post: 18th Aug 2010, 13:23 -
DVD LAB PRO - color map
By blackmiles in forum Authoring (DVD)Replies: 5Last Post: 14th Apr 2010, 03:56 -
DVD-lab PRO v1.6 - "Map" only gives the color black
By Paker in forum Authoring (DVD)Replies: 1Last Post: 3rd Sep 2009, 14:30 -
Can a DVD recorder change a DVD color system?
By coody in forum DVD & Blu-ray RecordersReplies: 6Last Post: 14th Dec 2007, 13:16
