I have a Lite-On 411s and a Pioneer 16x DVD ROM drive. Both rip at a speed of 1.6x, even though they should rip much faster. I have WIN98SE 356 mb of rdram, pentium 4, geforce 3 ti. My computer is way over the min requirments yet i still have no idea why it rips so slow. I turned DMA on my hard drive but can't figure out how to turn it on on my recorder and dvd rom drives. I went to device manager and DMA was not there.
Can anyone help me with these two problems please?
The 1.6x ripping speed indicates the drives operate under PIO mode.
To enable DMA you need to go to Device Manager, System, display the devices tree and go to the IDE controllers, primary and secondary.
You will see two settings for each controller, one for each device.
If any is indicating PIO Mode only, change it to DMA and save the settings.
You will need to repboot.
The Pioneer should be giving you at least 4x ~ 8x with dual layer CSS protected disks.The more I learn, the more I come to realize how little it is I know. -
I went to where you said and there is no option to check DMA or PIO. I have WIN98SE if that helps. I was able to switch my hard disk to DMA, but there isn't an option under hard disk controllers or for my burner. Help please!
Daemon Tools can slow rip speed
By ocgw in forum Blu-ray RippingReplies: 8Last Post: 11th Nov 2013, 11:07 -
Win7: slow down dvd speed
By themaster1 in forum ComputerReplies: 4Last Post: 1st Jan 2012, 19:03 -
NTSC DVD player that allows you to slow down playback speed?
By eurotimes2 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 31st Aug 2011, 00:46 -
DVD skipping problem. Slow drive speed.
By rayden54 in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Jan 2010, 15:37 -
Ativa 18x dvd writer is real slow and tried everything to speed it up!!
By rotwiler in forum DVD & Blu-ray WritersReplies: 6Last Post: 13th May 2007, 00:21
