I am having a problem, using "DVD Shrink" I am trying to back up my DVD's. the problem, I am having is, after I try to rip using "DVD Shrink", The files are in vts format. I tried using "DVD2AVI" to read them, but no luck. "TMPGEnc" can't read them either. So far I am stuck. Can someone please tell me what I am doing wrong. Thanks In advance...
what are you trying to do? how are you going about backing up your dvds? sounds like you want to convert to another format, not back up. makes sense though...with only a 13G HD you really can't do much with vob files. please elaborate...
There are two ways:
1) SmartRipper -> DVD2AVI -> TMPGenc
takes a long time to convert, useful to back up to VCD, SVCD
2) DVDDecrypter -> [optionally DVDShrink] -> burn to DVD
this method is much much fasterktnwin - PATIENCE -
ok, I used, "DVD Shrink" first, to rip the files, then I tried to use "DVD Decrypter" with no luck. I just can't figure out what I'm doing wrong. Any help is Appreciated...
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 24th Sep 2007, 00:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 22:31
