I am making a VOB file from a short DVD-compatible MPEG2 test capture (720x480 resolution). Is this done via transcoding? That is what Nero VisionExpress does with the MPG file. However, the resulting VOB file is much larger (162MB) than the MPG file (133MB). Is this a problem with VisionExpress or do other tools do the same? I thought that if the mpeg2 file is DVD compatible, the size of the VOB would be about the same. Why the size increase? I didn't create any menus in VisionExpress, and I even tried to lower the bitrate, but the VOB file is still larger.
Also, the VisionExpress creates the folder structure, but only for VIDEO_TS. It does not create AUDIO_TS folder. Is this normal?
JoeT
Results 1 to 1 of 1
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
Can I get VOB to smaller file size with no loss of quality?
By Joolz2020 in forum Newbie / General discussionsReplies: 17Last Post: 23rd Aug 2010, 14:11 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
VOB file size problem
By mb1512 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2008, 16:58 -
larger file size from .avi to h264
By sai351 in forum Video ConversionReplies: 3Last Post: 4th Jun 2007, 14:20
