Although I have searched through the guides I cannot find the answer I am looking for so here goes.
I have some Episodic disks with 4 episodes per disk. I would like to split each DVD-9 to two DVD-R with two episodes per disk but I would also like to have seperate menus for each disk ie the same menu from the original disk with options to select episodes 1 & 2 for disk 1 and so on. I dont know if this possible so if anyone out there can help I would be extremely grateful.
I have the guide on the DVDshrink method but I would rather not do that unless I have to.
Can't help you with your question, but it would help to know what DVD Authoring program you're using. That way someone who really knows that program can maybe fiddle with it to derive you an answer.... or maybe they just know!
Good luck! -
Adam
DVD Decrypter>DVDShrink>CopyToDVD -
Elby CloneDVD can split 4-episode disk quite easily. I'm doing it with Star Trek DS9 episodes. Just select the first two episodes,then repeat for episodes 3-4. It preserves the menus so either of two episodes can be selected,if you select and episode on the other disk it recycles back to the menu. DVDfab can also do it.
Episodic DVD Rip Question
By Eternal7331 in forum DVD RippingReplies: 14Last Post: 18th Nov 2013, 19:36 -
Episodic DVD ripping problem
By grandmastashi in forum DVD RippingReplies: 5Last Post: 10th Jan 2011, 09:43 -
Episodic DVD + menus Authoring
By Instant Martian in forum Authoring (DVD)Replies: 48Last Post: 22nd Apr 2009, 11:42 -
menu for episodic dvd using only freeware?
By awiseguyay in forum Authoring (DVD)Replies: 3Last Post: 5th Apr 2009, 16:35 -
I want to reauthor an episodic dvd
By peterhun in forum Authoring (DVD)Replies: 5Last Post: 22nd Jan 2008, 18:02
