  1. I am having troubles copying multi-episode dvds such as Futurama and Brasseye. The setup I use atm for normal dvds is: dvd decrypter to rip onto HD; dvd2one to shrink dvd; prassi primo DVD to burn. This method has been very succesful for me so far.
    Do multi-episode discs need to be done any differently? I just want a direct copy with all the original menus. Have tried a couple of times with above method but the menus end up all messed up when burnt (see my post for more details here ).
    Whats the easiest method for a straight copy of multi-episode dvds?
  2. Member wulf109's Avatar
    Jul 2002
    I would suggest you try Nero for burning. I use the same method and have never had a problem with the menus.
    Prassi and it's clone Record Now seem to modify the ifo files and that could be your problem.
  3. thanks wulf Im going to give that a try now...
