  1. I recently purchased the retial version of Instant Copy 8.... I want to burn DVD's with functional menus....but no extras like directors commentary and stuff like that.... I just want the menu I can have so I can choose scene selection and stuff.
    I recently copied Finding Nemo with Instant Copy and DVDecrypter with no problem....but I want better movie quality....so im sure deleting the extras and directors stuff would do that for me....any idea how i can do that please help
  2. sk1pmcgee
    With IC8 that is very simple to do... Simply select movie only and choose to keep the menu.
  3. Will the menus be fully functional...........i mean the "Play Movie" and the "Scene Selection" will work...but i dont expect the other stuff to work
    Will those two that I mention work
  4. Yes they will work...If you accidently choose an extra on the menu you will get a blank screen for less than 1 sec and return to the menu.
  5. Ny Player thanx a bunch your a big help....one more question....say i want the deleted scenes choice in the extras...is there a way i can keep that on there... i know it will be a choice in the menu anyway...but instead of getting the blank screen for 1 sec.....can i somehow access like certain part of the extras if i want....
