hi, i've read through the tmpgenc problems page but still couldn't find a solution.
Every time i start up the wizard and go through it, when i select DVD, and load the file etc. At the last point, where it says output file, for some reason it is always selected as output as individual streams i.e m2v and wav??
I dont want it as two streams, and i cant change that setting. Ive tried using the unlock template but doesn't work either.
This has only occurred recently coz before i could encode and the output would be a single mpg file.
Any help would be greatly appreciated
thanks
yes, my version does have that option, but i'm unable to uncheck it. It becomes grey and i'm unable to change it.??
You might want to disable the project wizard then and just load the DVD template from program directory. Make sure your settings are as pictured in Tommyknocker's post. If it is grayed out then load the ulock file.
You need to select the audio to be encoded to mpeg1 layer II, an m2V and a PCM wav cannot be multiplexed that is why they are output as seperate files. I think with the later version of TMPGEnc you can select the audio to be output as LPCM and this is probrably what you have done, is the wav file very large. If you select MP2 for the audio you can select to output the audio and video stream together as an mpg file.
that was it !!! thanks craig !
I changed the audio to mp2 and problem solved.
Thanks again for the help -
No problem
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
