Holla all, i use nero 6 i had a 1x dvd-r's and used to burn at that speed now i just got a batch of DVD-r's that are 2x, however nero still only burns them at 1x speed.
i tried the little drop down box to change the speed but the option is not there, any ideas????
It's not Nero,it's a limitation of your DVD writer. Just because it's 2x doesn't mean it will burn at 2x. The media your using must be properly configured in the recorders firmware in order for it to see the media as 2x.
Well its a 4x dvd writer ok im very new at this how do i update it to recognise a higher speed
Make sure you have DMA enabled. If the IDE channel your writer is on is PIO only then this would cause slower than expected burn speeds.
http://www.dvdidle.com/dma.htm
Try that, or go here:
http://dvdxcopy.afterdawn.com/thread_view.cfm/20775
this is how other people solved it.
Old bug with windows not rechecking if DMA is available
after some wrong answers from the media?
What software burns avi to dvd without having to convert??
By bradztheman in forum Video ConversionReplies: 3Last Post: 20th Jan 2012, 20:41 -
Best avi to dvd software that burns
By mol3000 in forum Video ConversionReplies: 1Last Post: 19th Aug 2010, 00:19 -
Keep getting bad DVD burns after OS reinstall
By brassplyer in forum ComputerReplies: 18Last Post: 20th Sep 2009, 02:12 -
DvD R9 burns disks ok but cant read them
By craftycelt in forum Newbie / General discussionsReplies: 6Last Post: 1st Mar 2008, 18:56 -
CD Copy with Nero Fails after a few burns
By kadzbiz in forum MediaReplies: 7Last Post: 5th Feb 2008, 20:46
