Hi all,
I am wondering if one could place a small exe (SVCD player) into one of the folders created from Nero and if the disc would still be considered compliant or not?
I also would like to know if the same thing can be done while authoring a VCD and what folder is used for both SVCD and VCD.
I'm pretty sure that players just ignore anything they can't use. Also, the ISO filesystem goes in a separate track, so it's not going to screw with anything. I think it would still be compliant, and even if it's technically not, it won't be a problem.
I have placed files in various folders and so far so good.
I haven't found a good, small SVCD player for windows that I can put on - if you know of one let me know.
Also for regular VCDs I author a script for Media Player but the scripting language is retarded. A VCD 2.0 player with PBC would be great. -
You shouldn't have any problems placing other files on an SVCD or VCD as long as you don't overwrite any of the critical files created by Nero. Unless you have a really anal player, it should just ignore any irrevelant files.
I usually pack WinDVD 3.0 with my SVCD/VCD's in a folder called WINDVD. So far, I haven't had any problems. -
You are allowed to add files to the ISO filesystem of a S/VCD. It is fully compliant and will not affect the disc playback in any way.
If there is a problem, the problem is with the player, not the disc.
Regards.
Michael Tam
w: Morsels of Evidence -
Thanks kindly for the reply’s folks, it's been awhile since I last checked the board
working 60 hours at the moment...
I have a small (under a meg I think) SVCD-VCD player that is freeware if anyone is interested. I can find a link or up an e-mail
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 16:23 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 19:09 -
WPDNSE folder inside your system Temp folder????
By MozartMan in forum ComputerReplies: 25Last Post: 27th Mar 2011, 08:35 -
Join dumped Deezer music files
By kkol123 in forum EditingReplies: 2Last Post: 1st Aug 2009, 22:48 -
explorer.exe / drwtson32.exe keeps closing
By coolcoates in forum ComputerReplies: 7Last Post: 28th Nov 2007, 08:42
