Ok here is my problem:
I have downloaded lots of mpegs and tried to author a dvd using them(TMPgenc dvd author). Before i authored them into dvd files the audio and video are fine.
But after authoring the audio in some episodes are out of sync, In some it starts out ok then get worse as it goes futher into movie file, But with some it seems bad at the start and stays that way.
Can anyone tell me a program that i can use that will help me fix this?.
I still have the original files used to create dvd files so i can redo these dvd's if the problem lies with my original files.
here is copy of the log from the \VIDEO_TS\VTS_01_1.VOB file
using PVAstrumento
Stream info for
C:\Documents and Settings\Desktop\for burning to nero\Volume 1\VIDEO_TS\VTS_01_1.VOB
VIDEO: Resolution 352 x 240
Aspect ratio is reserved (= 0xc)
Frame rate 29.97 fps
Nominal bitrate 1150000 bps
first PTS: 00:00:00.074
AUDIO: MPEG-1, Layer 2
48.0 kHz, Stereo
Bitrate 224 kbps
Frame Length 24.0 ms (672 bytes)
No A/V delay. Go celebrate !
==SCANNING==
Funny. Video and Audio start synchronously.
[ Found a GOP with more than 15 pics.
See summary for total number at end. ]
ALERT> Temporal structure wrong in GOP - dropping
Done.
Video bitrate: max 2663 , avg 1150 kbps
Video: 76404 pics 00:42:29.349
Audio: 106222 frames 00:42:29.328
DVD (un)compliance:
4059 GOPS with more than 15 frames
can anyone give me some ideas on how i may be able to fix thisNo program is idiot proof! I can prove it :-) -
What are the frame rates and audio sample rates on the input mpeg files you're having the problems with?
What is different between those files and mpegs that work okay? -
neo4u I had the EXACT same problem, I found the solution was that the AUDIO that was encoded when I captured the video (I used winfast PVR) was a wierd format and TMPGenc dvd author was re-encoding only the audio, not sure i fyou noticed its "re-encode audio to match output format" tick box?
I got around it by using a different capture program (dvd movie factory) that let me specify the exact audio format I wanted (mpeg layer 2 - 48000 - 256) Winfast was using some wierd 41000khz setting which TMPGenc re-encoded and stuffed up my synch (gets worse as dvd played)
so yeah try and get your captured video to exact DVD specs and TMPGenc wont re-encode then and it will all be in synch
You will know your audio is correct when TMPGenc dvd author tick box for audio re-encoding is NOT ticked by default.
- Jarin -
can you suggest a good program that will re-encode the mpeg to exact dvd specs
Audio Sync Problems
By eon_designs in forum Blu-ray RippingReplies: 2Last Post: 8th Dec 2009, 09:49 -
Audio sync problems
By jelockwood in forum ffmpegX general discussionReplies: 1Last Post: 30th Jul 2007, 12:03 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 06:22 -
I've got audio sync problems (too)
By gigantibyte in forum EditingReplies: 26Last Post: 10th Jun 2007, 10:17 -
Audio sync problems (again!!!)
By MadMaz in forum Newbie / General discussionsReplies: 10Last Post: 30th May 2007, 20:42
