Hopefully someone can just answer a few questions I have, as this is the first time I'm authoring a DVD this way.
I have a set of .avi files that I would like to burn to DVD to be able to watch on TV. Each file is roughly 130 mb. It isn't the best quality, but I can live with it,
I have been using TMPGEnc Plus to convert the .avi's to mpeg 2 in order to burn them to DVD. I'm finding, however, that even when I use a bitrate as low as 2000 that the resulting file size is often ~350-400 mb. When I try to make it a little higher quality with a bitrate of 4000, the file size can be between 600-700 mb, meaning I can only fit a couple .avi files per DVD.
Is this drastic increase in file size just par for the course, or am I doing something wrong. Thanks for any help.
Just don't use the project Wizard.
https://www.videohelp.com/forum/archive/t77381.html -
The filesizes look about rught but can't tell for sure.
the size of an mpeg is determined by the bitrate and running time only, nothing else. So the source file size and the resolution is of no relevance.
Hint. If your source is low(ish) quality, consider useing 1/2 D1 (352 * 480/576) resolution, or even VCD resolution (352 * 240/288). Lower resolution with low qual source allows you to use lower bitrates and still achieve the same quality (or very nearly) as the source. -
Pardon my ignorance, but how would I go about doing this? I can't seem to figure out how to do it in TEMPGEncOriginally Posted by bugster
When I select 352 x 480, it changes the shape of my video. -
It changes the shape, yes but it will play in the correct aspect ration on your DVD player.
AVI (with Ac3 audio) to DVD using TMPGenc 2.5 Plus
By CaptainChaos in forum Authoring (DVD)Replies: 7Last Post: 2nd Mar 2012, 08:03 -
AVI to DVD MPEG (CCE or TMPGenc encoders)
By DJRumpy in forum User guidesReplies: 674Last Post: 15th Oct 2010, 08:46 -
TMPGEnc DVD Author 3 can't import AVI video, only audio?
By XyBeRz in forum Authoring (DVD)Replies: 7Last Post: 31st Jan 2009, 10:54 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 18:11 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 15:37
