How do you get the correct aspect ratio in your VCDs?
It seems that using MacMPEG2Decoder -> mov and then Cleaner 5-> mpeg one produces square pixels, which look fine on a computer monitor with the aspect ratio preserved.
However, when playing widescreen VCDs, the pixels are not square but slighlty taller than wide. This produces an aspect ratio that make the picture look taller that it should, i.e. people have long faces, which look like crap.
A played around with the settings in Cleaner 5 but the resulting MPEG1 file is always the same with the aspect ratio not correct on the VCD disc.
Is this a problem with stand alone VCD players or can it be corrected in the conversion tp MPEG1 process?
Results 1 to 1 of 1
Multiple Aspect Ratios on One Disc
By gorcq in forum Authoring (DVD)Replies: 7Last Post: 20th Dec 2011, 21:35 -
iMovie and aspect ratios
By sphinx99 in forum MacReplies: 3Last Post: 10th Mar 2010, 23:18 -
Mixing different aspect ratios on the same Project
By MarioB in forum EditingReplies: 1Last Post: 6th Jul 2009, 06:40 -
Converting to Divx and Aspect Ratios
By matthewjohn23 in forum Newbie / General discussionsReplies: 8Last Post: 28th Mar 2008, 17:43 -
Aspect Ratios
By gayclarke in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2007, 15:13
