Ive downloaded a 700 meg movie which has been split into 12 mpeg files.
What is the best and easiest method of joining them all back together and burning them onto dvd-r so i can play it on my ps2 or another player?
Thanks.
Are they all the same framerate, aspect and use the same codecs ?. If so you can join them using mpeg tools in tmpgenc. Then export to say something like tmpgenc dvd author and then burn with say nero.
They were probably split with something like HJsplit. It's a common technique used by people who can't be bothered to make a proper split archive with winrar or stuffit, or winzip. Mostly found with porn
as those guys generally can't be bothered to get with the times. The other possibility is that they are many "sample" segments with a title at the beginning and end, again, mostly with porn
but you occasionaly find other mainstream content broken like this.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
Thanks guys for the info and yes its an adult film although its good quality broken into 12.
Ill give the software suggested a go.
Thanks.
DVD download Burning problems
By completeidiot in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 05:53 -
The Vital Message - General Fiction, download ebooks, free download, The
By spacek77u in forum DVD RippingReplies: 1Last Post: 14th May 2007, 01:29
