Hello,
I'm thinking about buying the Kworld V-Stream Xpert DVD Maker USB 2.0 Video Capture system. I was just wondering if anyone has heard anything (good / bad) about this product. I've tried searching the forums, but they weren't that much help. Thanks!!
I just ordered this external USB capture device. Any good or bad video capturing results out of this device?
I purchased this mainly because my Laptop's sound card does not have a LINE-IN.
So mostly I will be using the AUDIO-IN feature. It would be great however to use it as a video capture as well if it worked.
Been doing lots of video capturing and linear editing with good results.
I would be very "surprised if this "cheap" device could do what it claims to do. Looking forward to trying this device, especially the MPEG4 capture.
Cheers. -
i am using this with laptop i also hook the sound pin in MIC jack!
works ok!
and quality is not bad in this price range! -
MIC-in only gives you mono input not stereo, more over line in has higher impedance. If you plugin a LINE level to MIC in, the sound could be distorted.
Read my post regarding this device:
https://www.videohelp.com/forum/viewtopic.php?t=202070
I have returned that thing and got a Plextor PX-M402.
I am very happy with Plextor.
Sound wont work on KWORLD DVD Maker USB 2.0
By BiggerJim in forum Capturing and VCRReplies: 1Last Post: 24th Nov 2014, 07:06 -
kworld dvd maker 2 help
By itsicon in forum Capturing and VCRReplies: 39Last Post: 18th Dec 2010, 11:21 -
Kworld Expert dvd Maker - S-Video no picture
By johnstede in forum Capturing and VCRReplies: 3Last Post: 9th Aug 2009, 08:54 -
Problem with kworld dvd maker 2800D usb - Compression artefacts?
By jhowee in forum Capturing and VCRReplies: 5Last Post: 10th Feb 2008, 06:48 -
Hauppauge WinTV 2Go capture card was Kworld DVD Maker USB 2.0
By Vampire74 in forum Capturing and VCRReplies: 4Last Post: 19th Jan 2008, 10:59
