Does anyone know if version 1.0A is safe to flash with? I am using 1.08 right now with no problems at all and am wondering if it's even worth it. Does anyone know what this version fixes?
I flashed my drive a couple of days ago and it seems to be working fine. I've burned a few disks and no problems. I don't see any difference but I'm using the same media. The update says that it supports more media. Unless you're having a problem with some media type I wouldn't flash it. Better safe than sorry.
Umm.
How can you have 1.0A.... but say you are using 1.08???
I am saying this because 1.04 was just released last week for the IndiDVD (TDK).
Quality TDK Media?
By hech54 in forum MediaReplies: 15Last Post: 24th Jan 2010, 20:42 -
what is wrong with these TDK?
By twister6 in forum MediaReplies: 21Last Post: 26th Feb 2009, 14:50 -
TDK now Imation - updated 10-30
By BiggerJim in forum MediaReplies: 1Last Post: 29th Oct 2008, 17:21 -
TDK DVD+RW format before use
By nobbydadog in forum MediaReplies: 2Last Post: 30th Apr 2008, 09:55 -
What should I do with these TDK's
By Waltj in forum MediaReplies: 6Last Post: 3rd Jun 2007, 00:27
