HI Guys and Girls
A question about FFMPEG can it speed up AC3 NTSC 23.976 frames to Pal 25 Frames and keep the 6 channel format
Pls help me
My damn TV cant display NTSC
No.
You can decode the 5.1 ac3 to 6 separate wavs, then do the frame rate conversion on each wav, then recreate the 5.1 AC3, but it involves lots of work, disc space and exotic software.
Take my advice, and decode to stereo wav, do the frame rate conversion, and then reencode to 2 channel stereo AC3.
/Mats -
Thx for the advise.
That is what i been doing all the time, so i will stick to it
Thx 8)
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum Capturing and VCRReplies: 1Last Post: 14th Feb 2012, 05:11 -
Which ffmpeg options are used behind the scenes by ffmpeg?
By roberto.aloi in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2011, 06:09 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 13:04 -
Difference between ffmpeg -threads and ffmpeg-mt
By Calidore in forum Video ConversionReplies: 2Last Post: 7th Mar 2010, 23:44 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 03:55
