i have some video files which are encoded in the 352x240 and 29.97 fps format. when i use tmpgenc to convert the files to pal format the result file is ok for use on pal systems but the movie is very jerky in file playback. could you pls suggest an alternative.
Don't convert to PAL. Most PAL equipment plays NTSC material fine. Just author - I guess it's VCD mpegs you have, so just author using VCDEasy to VCD.
/Mats -
It is complicated, unfortunatelly...
The theory behind:
- You Inverce Telecine you source from 29.97 to 23.97. If your source isn't true film and it is true interlace (let say a TV studio transmission), this proccess is still possible, but somehow harms a bit the motion.
Unfortunatelly, for that kind of source, there is no other way to do it better with mainstream hardware / software. You have to do it with IVTC techincks.
- You boost your 23.97 result to 25fps and also resize to a PAL framesize.
- You speed up the audio so to match with the new boosted source of yours
- You encode to PAL -
I would say that if its an NTSC Film file (like a DVD Rip) then do what SatStorm says and speed it up from 24 to 25fps and resize to PAL dimensions. If it's standard 30fps NTSC then just burn as an NTSC disc and virtually all DVD players will play it correctly.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 09:40 -
Newbie : How to convert PAL into NTSC Format for Video Cassette Player
By kato2010 in forum Newbie / General discussionsReplies: 7Last Post: 11th Sep 2010, 10:40 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
convert pal dvd to ntsc format?
By butt_crack in forum Newbie / General discussionsReplies: 2Last Post: 16th Aug 2007, 23:26
