  1. when i purchased the tdk velocd cd-rw drive, i used to always use it for cd ripping, and 2 years later, it will only burn at 8x max, and any higher will cause a coaster. and when i browse cd-roms using the cd-rw drive, it locks up sometimes. is this because i used it too much for reading purposes? even installing games, and saving pc games into .img format.
    now i just got the lite-on dvd-+rw LDW-451S
    what if i use it as my default drive for playing dvds, and using it to rip dvds for transcoding?
    is this safe?
    thanks
  2. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    Hello.
    I would never, ever, ever use my DVD-r/Ram drive for ripping.
    I don't even use it for playing.
    I buy a standard Lite-on DVD-Rom for reading (and the occasional rip) and replace it when it starts to fail.
    What are they ££££ where you are?
    Over here you can pick one up for £25 ($47; man, the dollar is low nowadays!!!!!!).
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
  3. Originally Posted by Will Hay
    Hello.
    Will
    I heartily agree and do exactly the same why rip on a high end dvdr when a dvd rom will do the job just as good and save some wear and tear on your precious dvd-r
    If it's wet, drink it
    My DVD Collection
