Is there any program that allows frame capture of SVCDs? PowerDVD and WindDVD don't seem to allow it.
WinDVD allows it. I think the shortcut key is "P" and it stores the bmp in the capture folder under windvd directory.
Also, I can't remember if you can open the mpg in TMPGEnc but it does allow you to capture frame.
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
Dropping one single frame in a two hour capture?
By justin81 in forum Capturing and VCRReplies: 5Last Post: 13th May 2010, 09:38 -
Still Frame and Field Capture?
By swingmaster in forum Newbie / General discussionsReplies: 1Last Post: 10th Mar 2009, 09:28 -
All Frame's Capture to show In one big Pic . ??
By lostnucleus in forum Newbie / General discussionsReplies: 11Last Post: 28th Feb 2008, 04:24 -
image shift in frame with Virtualdub capture
By Knightmessenger in forum Capturing and VCRReplies: 0Last Post: 27th Aug 2007, 00:16
