I have a PIII 866Mhz 128MB RAM Computerwith a new firewire card and cable. I would like to capture some Hi8 Tapes from my DV Cam through the firewire card. I have tried using Adobe Premiere with default settings, but for 40minutes I get a 10GB *.avi file
. Is there any way that I can output a smaller, but equally good quality file. My HD is only 30GB, and I would like to store several videos. Thank you.
That setting sounds about right. For DV video I can only reccomend you get a bigger hard drive. Im working with 120 GB's and sometimes it can be trying.
You are transferring a file in DV avi format. DV avi is 13Gb per hour. From a Firewire source this is usually the only format you can use although I believe some software will encode to mpeg on-the-fly. This will give you two problems. Your pc is probably not a high enough spec to be able to do this reliably and smaller files = lower quality. Buy a second (big) hard drive.Originally Posted by leafzfan50
Capturing Help
By Kyoji24 in forum Capturing and VCRReplies: 4Last Post: 23rd Apr 2010, 07:37 -
What are you capturing?
By ryangarfield in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2010, 15:16 -
Is my PC up to capturing from my camcorder?
By alhenderson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 21st Sep 2009, 03:54 -
Capturing help.
By fuseek in forum Capturing and VCRReplies: 0Last Post: 6th May 2008, 10:49 -
Capturing in HD
By The Sumerian in forum Capturing and VCRReplies: 1Last Post: 7th Jun 2007, 12:40
