  1. Well I gave up on dvDx copy platinum
    ( the headaches that gave me &
    IFO edit wouldnt work either) .
    & tried a Dvd decrypter , Dvd2one
    & copy DvD combo
    I want the entire movie intact on 1 disc
    (as why I tried DvDx copy platinum till my head hurt) .
    & Tutorials all say this is possible.
    All goes smooth until copy2DvD
    goes to burn the DvD
    There i`m told the file is over 4.37
    Gigs (it`s 4.47) , & wont fit on disc
    which is 4.7 gig memorex DVD-R
    Do I want to continue burning
    & even if I set copy dvd to required size
    & continue anyhow , another error message
    pops up saying I need @ least 4.48 gigs of disc space
    & it wont fit on my media (memorex DVD-R , 4.7 gigs
    in size) .
    I`m banging my head on the monitor by now . What gives
    here .
    Please give some much needed & appreciated advice
    Dec 2003
    Florida, USA
    Use what my signature has. DVD Decrypter, then DVDShrink, then CopyToDVD. Should have no problems. Hope that helps.
    Adam
    DVD Decrypter>DVDShrink>CopyToDVD
  3. short version is your movie is to big. the max your blank dvds can hold is 4.36 GB
    Jan 2002
    Not the end of the world!
    Though the blank dvd disc say 4.7gigs, in reality that translates to 4.36 to 4.37 per disc.
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    ...or DVDShrink (99.9% of the times, no need to rip first), then Imgtools Classic, then any burning app that knows how to burn an ISO (I use DVDDEcrypter).
    /Mats
  6. I think if you have Nero installed you can burn directly with DVDshrink 3.1.2
    4,700,000,000 Bytes are equal to:
    - 4589843.75 KBytes (= original value / 1024)
    - 4482.26 MBytes (= KBytes / 1024)
    - 4.37 GBytes (= MBytes / 1024)
    so 4.7 "decimal" GBytes = 4.37 "computer" GBytes
  7. Banned
    May 2003
    Massachusetts
    It really is quite misleading, isn't it?
    Basically for whatever reason, people who manufacture media (be it hard discs, DVD burners, or blank CD's) have permission from the government to use one MILLION bytes as a megabyte, and one BILLION bytes as a gigabyte. In reality, a megabyte is:
    1024*1024 = 1048576 bytes. That's off by 48k. Not so much, you say?
    Well, a gigabyte really is:
    1024*1024*1024 = 1073741824. A difference of 73 Megs.
    Now, using this math, 4 "gigabytes" adds up to almost 300megs of "difference". That's where your missing space has gone.
    - Gurm
    Oct 2003
    deep in Wonderland.
    Your question has been covered pretty well by now, so all I have to say is you'll learn a lot on this site, so feel free to...
    ...hang around.
    I'll be here all week. Try the veal!
    Fight spammers ghetto kung-fu style! Join the Unsolicited Commandos! or the Spam Vampires!
