Could someone explain to me the difference between Disc-at-once and Track-at-once?
Also, how big of a file is it safe to overburn, as data, to a 700m disc?
Thanks....again.
Quite simply, TAO turns off the laser between tracks, while DAO does not. This was copied from the Nero help file included with the program...
Disc-at-once
With 'Disc-at-once', the whole medium is written in one go without deactivating the laser. In the 'Disc-at-once/96' (DAO/96) process, more data is written, which can produce better results for actions such as copying CDs.
Note: Audio, video and Super Video CDs should always be burned using Disc-at-once even though it is also possible to select Track-at-once. We do not recommend using Track-at-once. It is better to use Disc-at-once/96 for copying CDs.
As for overburn, you can most likely go to about 703 MB, but you could risk data corruption beyond that. You can experiment with a disc you don't care about too much, to see how far you can go. It will vary slightly from manufacturer to manufacturer.Ethernet (n): something used to catch the etherbunny
Two simple questions, plz help!
By UnD3R0aTh in forum DVD RippingReplies: 40Last Post: 4th Mar 2010, 10:47 -
Some simple questions about Dreambox and HTPC
By Talayero in forum DVB / IPTVReplies: 0Last Post: 8th Apr 2009, 11:44 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Nero Burning Rom 8.3.6.0
By jebinio in forum ComputerReplies: 1Last Post: 14th Sep 2008, 10:29 -
how to create folders in nero burning rom or express?
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2007, 23:54
