Every time I set the time to edit the mpeg file its not following the times I am giving it. It's cutting it short on me.
Does this program just not edit to exact timing???
TMPGenc Plus should, using it's mpeg tools ->merge/cut -> edit function.
But, if source mpeg file was not encoded by TMPG+, might try running the source file thru a merge by itself to a renamed file so that any incorect header info can be cleaned up...
TMPGenc DVD Author will not. (your post didn't say which you were using)
Problem Splitting MPEG and rejoining with mplex
By jon111 in forum Authoring (DVD)Replies: 6Last Post: 3rd Mar 2011, 21:13 -
TMPGEnc MTS to mpeg-4 problem/question
By Justice37 in forum Video ConversionReplies: 0Last Post: 11th Aug 2010, 16:30 -
Splitting vob(mpeg)
By Peterrrrr in forum EditingReplies: 4Last Post: 17th Nov 2008, 12:24 -
problem splitting mpeg with tmpgenc
By jensiq in forum EditingReplies: 16Last Post: 16th Sep 2008, 08:18 -
splitting an mpeg-2?
By php111 in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2007, 18:18
