What writing parameters do you need to write divx to CD using Nero so that it can be successfully read by the Lite-on DVD player?
Nero for me is defaulted to: checked - multisession Should multisession be checked?
Otherwise I assume I lay it down as a data CD such as "move one.avi".
Can the Lite-on play the most common divx format 5.0.2 or 5.0.3?
I may be burning about 40 divx movies, so I want to be sure to do it right.
Multisession should only be checked if you are going to add files later to the disc. Otherwise, you should check "no multisession" and use DAO mode (disc at once) to be sure the disc will be read. You won't need to add files anyway, if they are close to 700MB they will use up all the space on the disc in any case, so there's no need for multisession.
Yes, the LiteOn can play DivX 5.0.5 and 5.1.1 without difficulty. Also XviD and DivX 4, but has some problems with certain DivX 3.11 files. Depending on bitrate, those may or may not play properly.Ethernet (n): something used to catch the etherbunny -
What Rounadabout says. In Nero, set for Disc At Once, No Multisession and Finalize the disc (I guess this is no multisession). If you don't Finalize, then the player may not read it.
If you have Nero Express, it's so easy now to do data discs. Open a new Data disc, add your file(s), the click Next. When you get to the screen where you can change the Disc Name (default=MyDisc), there is a button at the bottom called More Options. Click that. Change Track at Once to Disc At Once and Click the Finalize disc box. Click Burn and you;re off to the races. -
Thanks for the clear consice answers. That's what I prefer to is Nero Express. Thanks again.
Does K-Lite mega Pack support Nero 7?
By Djard in forum Software PlayingReplies: 37Last Post: 20th Sep 2010, 08:10 -
How do I burn a dvd with nero using ffdshow from k-lite pack
By sxpredman in forum Newbie / General discussionsReplies: 7Last Post: 7th Nov 2009, 02:20 -
Lite-On 5045GDL+ and bug with DivX & XviD playback?
By NorseGuy in forum DVD & Blu-ray RecordersReplies: 0Last Post: 2nd Apr 2008, 11:51 -
Lite-On lvw-5004 (europe) question
By dynalink_user in forum DVD & Blu-ray RecordersReplies: 1Last Post: 16th Aug 2007, 08:53 -
Lite on HD-A740GX input question/problem
By Dekaspace in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 20:32
