Panasonic E-80
Is there a way to stop that annoying freezeing that happens when the scenes change.
Im recording my shows I taped on video onto dvd. Im recording in Dolby Dig. I then cut out the commercials and then place a chapter marker at all the comercal spots. Now when I play back the show on the recorders HDD there is no Noticable freezing. But when I transfer to DVD-R then watch it freezes for about a sec at the start of each chapter!
Dose any one know a good way around this? it also freezes when I play the DVD-R on my other normal DVD player!
Thanks for the time!
Oh yeh, I just remembered...
Are you high-speed dubbing that off the HD?
When you shorten segments, it changes the GOP or whatever its called...
So, to avoid that you must dub at 1x to dvd-r so that it re-encodes.
I'm fairly sure that is the cause/solution.
dvddecrypter stop recognize dvd in drive, got img burn,it stop recognize
By ninjinturdle in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2011, 12:30 -
Building a new PC - This is annoying
By Des in forum ComputerReplies: 5Last Post: 9th Jul 2010, 16:54 -
Isn't this annoying?
By Midzuki in forum FeedbackReplies: 17Last Post: 4th Feb 2008, 12:34 -
The Most annoying Celebrity
By Cirone in forum Off topicReplies: 22Last Post: 4th Feb 2008, 12:32 -
Annoying error i keep getting...
By SE14man in forum Newbie / General discussionsReplies: 5Last Post: 1st Jan 2008, 03:33
