ok, this is my prob, I'm trying to make vcds with mpeg 2 files but when I vcd them it tells me that it's the right file type, so it tries to convert it (btw using nero xpress) the thing is that when it's done converting there's this huge lag betwen the audion and video, go I figured maybe it was nero's conversion that did this... now I found out that mpeg2 are supposedly used for svcds so I tried that, but on my player (Koss Kd260) when I put the cd in it makes the menu skip and and black instead of blue, and when I get into the video it rotates vertically and is still black and blue... now I was wondering if there was a way to maybe conver the files to normal mpegs so that I could vcd them, or maybe someone could tell me how to svcd them properly for me to view them on my player...
might try this guide for help:
https://www.videohelp.com/guides.php?howtoselect=4;11
Problems converting H.264 AVC to MPEG2
By Gwar in forum Video ConversionReplies: 8Last Post: 4th Jul 2011, 11:29 -
Problems with converting avi to mpeg2 with HC enconder...
By sgbd in forum Video ConversionReplies: 2Last Post: 29th Nov 2010, 04:07 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
Converting MKV to Mpeg2 audio problems
By anfield7 in forum Video ConversionReplies: 1Last Post: 22nd Feb 2010, 07:39 -
converting to mpeg2
By thecrock in forum Newbie / General discussionsReplies: 11Last Post: 12th Nov 2007, 16:08
