I know it isn’t a problem to transfer from DVD-RAM to the hard drive, but when I tried it with DVD-R it wouldn’t do it. The manual doesn’t seem to be too clear about it.
Is it possible? I’m not talking about copy protected DVDs, but DVD that was recorded on E-80 to DVD-R, but now I need to copy it back to the hard drive. Thanks!
Results 1 to 23 of 23
Yes, you can run another dvd player to the inputs...or even easier...i've been told you can simply run a line out of the E80 to the line in of the same E80 and it works.
I know what mean.....a few of us here think along the line....of StandaloneOriginally Posted by Shtirlits
but this forum covers ALL DVD Recorders.
Should there be a separate forum? -
No you can't do that. I believe manual is very clear about that. No dubbing from DVD-R to recorders HDD. On the other hand... Pioneer can do that :POriginally Posted by ShtirlitsPinnacle Studio 8 and DV home video editing (ver.9 already home)
Yes....you can do that, and I have done it. You can play another dvd player into the inputs, just like a vcr, and record to the HDD. I have also seen confirmation that you can play a dvd-r in the Panasonic, run the line out to the line in as a loop, and record to the HDD. The manual is referring to copyrighted dvds.No you can't do that. I believe manual is very clear about that. No dubbing from DVD-R to recorders HDD. On the other hand... Pioneer can do that
Well.... you are right and at the same time you are wrong.Originally Posted by sugeknight
Yes you can do what you are saying... You can connect any non-protected video source through external connectors and record it to Panasonic. Even DVD Player.
No you can not place DVD-R into Panasonic itself and "copy" (copy.. not re-encode) material to HDD like you can do with DVD-RAM. This is what manual is refering to. Pioneer can (some special requirements for "non loss copy"="high speed" and "re-encode" is always an option)Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
by making use of the machines simultaneous record and play capability, you can simply connect one set of outputs on the recorders back to its own inputs. select the correct input (hint: in will look as if the screen is melting, but dont be worried about that). first, select the HDD side and press record, then select the DVD side and play the material. you can make use of the dmr's great editing features by trimmimg any beginnig or end excess you see fit. i have permanentley wired my recorder this way, it is very useful. its even better when you utilize FR for material that is less than two hours, etc.
[quote="donpedro"][quote="sugeknight"]
I'm ok with re-encode, but how?No you can not place DVD-R into Panasonic itself and "copy" (copy.. not re-encode) material to HDD like you can do with DVD-RAM. This is what manual is refering to. Pioneer can (some special requirements for "non loss copy"="high speed" and "re-encode" is always an option)
When I placed DVD-R in the Panasonic itself and hit DVD play it plays, but in order to re-encode I need to switch to HDD and when I do that DVD stops playing. How do I re-encode from DVD-R to HDD? Thanks! -
That is interesting...do I connect loop video out to video in and then what are the steps to record from DVD-R to HDD? Thanks!Originally Posted by the phantom
I said that it can be done on Pioneer, not on Panasonic. Try what the other guys are saying.Originally Posted by ShtirlitsPinnacle Studio 8 and DV home video editing (ver.9 already home)
When your connecting the output cables to the input, does the mechine change the signel from digital, to analog, back to digital? Basicly does the mechine convert to analog for playback? If so there might be some loss of quality. With a rip to HD there is no loos.
Thanks Mike. -
I do it and here's how: You're going to run your audio/video outs to your audio/video in on the Panny, yes, into itself. Hit record on the hard drive, while it is recording, switch over to the DVD player in the unit and hit play, this works and I do it when I have something on DVD that I want to edit - so don't tell me it doesn't Don Pedro! Hey, did you save up enough from your allowance for a recorder yet? :P
Originally Posted by Captain Satellite
You are not listening what I am saying. You can not COPY from DVD-R to HDD directly without re-encoding as you can from DVD-RAM.
From DVD-RAM you can copy 1 hour video in XP mode (let's estimate speed) in 15 minutes. High-Speed. What it does is, that data are copied like in PC from one medium to another. Without re-encoding.
This can't be done with DVD-R.
What you are doing is different. I hope I made myself clear.
Mr. Satellite,Originally Posted by Captain Satellite
Indeed, what you describe is not "dubbing," as the very title of this message was requesting information about. You are simply "recording video," just like you would be doing if you hooked up a separate DVD player to the E80H and started recording video played from it.
"Dubbing" refers to going into the E80H's "Functions" menu, then selecting the "Dubbing" feature.
Also, unless you're actually doing "high speed" dubbing, you are "re-encoding" the video signal, even if you're "dubbing." Generally, when folks are talking about this kind of "dubbing" back and forth between discs and the hard drive, they're usually wanting to get the "lossless" kind of transfer from one medium to the other without re-encoding the video.
The story remains that you cannot perform a "dubbing" operation from DVD-R to the HDD in the E80H, like you can with a DVD-RAM disc. Sure, you can do a "work-around" like you mention, but nobody would consider that "dubbing."
Give it a rest. Please.
thoots -
Indeed, the title states dubbing and led to one forum user asking how it can be done, even if it was not lossless, that is what I was responding to. Read the entire thread before you wave your magic wand.
Thank you! I tried it today and it worked! Thanks again.Originally Posted by donpedro
Of course it did, I knew what you meant all along.Originally Posted by Shtirlits
Shtirlits, now the question is "What worked ?" . It seems that there is different interpretation of your success
Connecting out into in on the player, then pressing record on HDD and play on DVD. It record DVD-R on the HDD just like if Panasonic was connected to another DVD player or recording from a TV channel. It isn’t dubbing like it’s possible to do from DVD-RAM, but works for me for now.Originally Posted by donpedro
Good to know that Captain Satellite's method worked for you
Goo luck with your recorder
Captain,Originally Posted by Captain Satellite
With some guys determining the utter uselessness of the E80H (usually in comparison to the Pioneer units) because of the lack of a "dubbing" capability from DVD-R to HDD, I just wanted to make sure we were all abundantly clear on what we were calling "dubbing!"
thoots
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
Problem: No dubbing from Sony HD camcorder to hard drive of HDD
By 1234567 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 26th Feb 2010, 23:43 -
Backing up Panasonic DMR-EH60 hard drive contents
By Jonesy127 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 9th Mar 2009, 12:42 -
New Panasonic Recorders with Hard Drive?
By duffy76 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 15th Jul 2007, 12:51 -
Panasonic E80 hard drive crash
By csanders1962 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 25th May 2007, 18:57
