Hey,
I have edited my home movie in Premiere. It's a basketball game. I want to add the score at the bottom after baskets are scored and the action is heading back up the floor, a la, regular TV broadcasts. Any quick Ideas? I can't figure out this whole title thing.![]()
Here's the tough question. At the end of the game, after I fade to black, I want to fade back in to a stat sheet with each players game stats, points, shots, fouls, etc. It's easy enough to do in Excel, but I can't seem to get anywhere going that route. I have photoshop, but no real idea how to do the text thing there. In Premiere, I tried to type in a test page, but I never figured out how to save it or anything. Is there any easy way to do this?
Thanks a LOT!
Augster
12 views. No replies eh? NOBODY must use Premiere. I can hardly believe that. Not even the admins?
Up. -
There are a lot of ways you can do this. It all depends on wich way you want to go. I do my son's football videos and I put in a score bug in the upper left corner that shows the teams, the date, and the score. I made the score bug in Photoshop, then imported the psd with transparent layer into Premiere. Then I set the transparency to white alpha matte. I put it over the video track and adjusted the alpha channel to fade it in and out.
If you want to just use a tittle, then click File > New > Tittle. Type your tittle and set it as Lower 3rd. That will center it in the lower part of the screen.
For some great tutorials, go to www.wrigleyvideo.comGot my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Thanks Racer-X.
I have photoshop 6.0. Unfortunately, I never really learned how to use it, and what you describe would be an almost impossiblity for me at this point without a LOT of reading and studying.
What you describe is exactly what I want to do. Unfortunately, I don't have the photoshop know-how to do it. Ack. In Premiere, the HELP section says to press T for text and such, and I don't even have that option. I don't know what the hell. Then I try the title thing, and it never lets me save it or move the title to a track or anything.
At this point, what should I do? Spend 4-6 hours figuring out Photoshop, or the same hours configuring the title in Premiere? Where would my time be best spent do you think?
Any help is greatly appreciated!
When you create a title in Premiere and save it - it should appear in your media bin - you then drag this to video track 2 or greater
you should also be able to drag the title from the title work area to the same place on the video tracks
Titles are automatically matted and anti-aliased -
Quite honestly, I think your time will be better spent @ www.wrigleyvideo.com
You can download Premiere Tutorials for version 6, 6.5 and Pro. They are video tutorials that will teach you a lot. Just download them and watch them. There is a tutorial just on Tittles that will explain everything you need to know.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
How to copy text styles in Premiere Elements 8
By Meertjeh in forum EditingReplies: 1Last Post: 16th Apr 2011, 14:57 -
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 09:54 -
Premiere Title Designer - Link Text To Chapter Name
By motown01 in forum EditingReplies: 0Last Post: 6th Oct 2009, 18:10 -
create text effects in premiere
By pmusser in forum Newbie / General discussionsReplies: 1Last Post: 13th Nov 2008, 17:30 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 11:38
