I asked a question for a couple of days ago in this forum (thansk for the help)
https://www.videohelp.com/forum/viewtopic.php?t=198955&highlight=
I have found out that is was my dvd player that cant play the movie. This i think is strange becouse it can play other dvd-r and movies that i have burned from dvd to dvd. But not when i download and burn it my self. I once dowloaded and dvd as an iso file and then it worked fine.
Is there a way to make the movie work on my dvd?
what is the filesize of the dvdr that will not play on your dvd settop? certain settops will not play dvdr's that are less than 4.0Gs.
example: recently backed up a disc...final size after taking everything i did not want out was 3.6Gs. dvdr will play in PC but not settop (BTW i have an Apex which usually plays everything and anything). redid the disc...this time included extra audio so filesize was about 4.1Gs. Plays fine on settop
TOOLS: Decrypter and Shrink.
will your dvdr play on another settop? what settop do you have? -
What type of player is it? I ask cause I have problems with my Toshiba playing the so called DVD-Video or ISO/UDF formats. The only format that will work on my Toshiba is UDF format. Don't ask me why or how, I just know that it works that way so I use it.
Have you tried to use the UDF format instead of ISO/UDF or the DVD video format?
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 13:07 -
HDTV makes DVD movie look "less" like a movie?
By breakchange in forum DVB / IPTVReplies: 73Last Post: 6th Oct 2011, 10:28 -
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 21st May 2011, 00:16 -
How can I convert a widescreen movie to full screen movie on PSP?
By VidHunter in forum MacReplies: 2Last Post: 9th Nov 2008, 23:20 -
Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!
By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 12:33
