I'll start with the specs.
Computer System:
Custom Built with:
Gigabyte GA-8IHXP Mobo
P4 2.4 Ghz 533 FSB
256 MB PC 1066 RDRAM
80 GB WD Special Edition HDD - 4 partitions Win98 boot, Winxp Boot for Protools, WinXP Boot for Video Editing, and Video Scratch partition (All NTFS except for 98 boot)
120 GB WD 2MB Cache audio Scratch disk - FAT32
ATI All-In-Wonder Radeon 64MB DDR, (The original Radeon chip...)
ADS Tech Firewire Interface
Protools Digi001 Audio Interface.
SB Live Platinum 5.1 with Live! drive
and Panasonic PVDV-400 MiniDV camcorder
Video capture goes off off without a hitch, but whenever I export back out to DV tape I always pick up a glitch or two. I have used Ulead Video Studio, MGI VideoWave, and Adobe Premiere 7.0. V S and VW usually drop a frame or two every 10-15 min. Adobe has audio glitches, but never aborts due to dropped frames.
Please help...
Results 1 to 14 of 14
Defrag your hard drives and turn off everything you are not transferring video with on your system.
Hello. -
I kind of had the same problems you are having and it was fixed by using Pinnacle studio 7, yes it has alot of bugs and glitches but it always seems to output to dv perfectly - give it a try what you got to lose
@tdowning,
https://www.videohelp.com/forum/viewtopic.php?t=157660
Yes, it's under the capturing forum, but may still prove of use.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thanks Y'all, Gotta get off to my "Day" job, will test the suggestions this evening.
@curryman:
Is Pinnacle Studio 7 considered to be a Consumer, a Prosumer, or strictly Professional program? -
close everything you have in the background: Antivirus, p2p's, firewall, messanger.... Everything u can.
There's a little program that does this automatically for you so you know everything is down, If memory serves me right I think it's called end it allclose everything you have in the background: Antivirus, p2p's, firewall, messanger.... Everything u can.
That End it All can do more harm than good, if you do not know what you are doing.
Hello. -
Well, I disconnected the network cable, and killed Mcafee AV, MS Messenger, (Never use it anyway...) and a few other things.
dump was a success, now to move on to the second tape finally.....
MiniDV video capture - on screen time/date stamp transfer
By Logan69 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 24Last Post: 29th Feb 2012, 15:02 -
Audio troubles, with firewire transfer from miniDV cam
By TheBigQuestion in forum AudioReplies: 29Last Post: 29th Sep 2011, 04:39 -
TRANSFER miniDV cassetes to BD
By mikehadj in forum Authoring (Blu-ray)Replies: 9Last Post: 20th Dec 2009, 06:46 -
Transfer data code while dubbing miniDV -> DVD+R using IEEE1394/iLink
By alokeprasad in forum Authoring (DVD)Replies: 0Last Post: 24th Dec 2007, 09:25 -
Transfer miniDV to hard drive. Does it matter what software is used?
By vid83 in forum Newbie / General discussionsReplies: 9Last Post: 11th Dec 2007, 20:08
