I heard that capturing wiht MJPEG for later conversion for VCD/SVCD is not recommended because it is a loss system being coverted to a lossless system.
I'd like to you more about this.
What is the real difference between capturing in uncomp/huff and Mjpeg in terms of converting to MPEG-2 (quality, size,time,etc)
Thanks,
Uncompressed or HUFF is lossless compression, where you can get a 2:1 data compression or so. It will save a little bit on your hard drive space, but not much. Mjpg has a wide range of compresion, from 2:1 to 200:1. If you stay under 10:1, the normal human eye will not notice the artifacts in moving images, but you might see it if you study a still image and look at edges. However, a 10:1 data compressin makes a huge difference in hard drive space, like a 20 gig file will only be 2 gig with a 10:1 "visually lossless" compression of Picvideo Mjpg compression. If you have tons of hard drive space, then use uncompressed video for a small increase in quality.
If you have the HD space and bus bandwith to spare use huffyuv, otherwise use MJPEG with a high ( PicVideo 17-19 ) setting. I use it all the time to convert to (s)vcd without any ill effects. Keep the compression ~10:1 or better or it will start to matter.
don't bother with uncomp when huffyuv is availible.
converting to mjpeg
By GodsOtherHand in forum Video ConversionReplies: 1Last Post: 7th Apr 2011, 16:03 -
Best way to go from MJPEG (1280x720) to small file size keeping quality
By Mysteriouskk in forum Video ConversionReplies: 7Last Post: 27th Nov 2007, 17:21 -
MJPEG Testing
By adambklyn in forum Newbie / General discussionsReplies: 1Last Post: 9th Oct 2007, 02:04 -
Need to export from Avid Meridien Uncompressed Mov to something else Uncomp
By rgabel in forum MacReplies: 1Last Post: 2nd Oct 2007, 12:54 -
DTV/SDTV Captue Question
By drprocrastination in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2007, 05:20
