I have 2 anime dvds that have 4 episode on them, I want to combine all eight episodes onto one dvd. Also i want to keep the subtitles. What programs do i need and what to do?
Thanks,
Raywong78
No menus though.
And 8 episodes on a DVD-R sounds like too much if you ask me. -
I checked all the guides, but don't know which one to use could someone point me in the right direction.
RayWong78 -
This si for DVDShrink 3.05, dont knwo if it works the same with 3.1
Just open both discs in seperate DVDShrink windows, then press the reauthor button to open another DVDShrink window, then just select and drag the main movies into the blank DVDShrink window that opened up when you pressed the reauthor button -
dvds to one dvdr guides:
https://www.videohelp.com/guides.php?formatconversionselect=DVDs+to+one+DVDR&search=Search+
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 18:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 13:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 09:59
Read guides on the left pane for precise instructions.
