I'm new to the burning end of things here and I'm browsing through the forums frequently to answer my questions. Here's one that should be relatively easy to answer that I can't quite pin down...I don't think:
How to you differentiate between a DVD5 and a DVD9? Can you tell by simply looking at the size of the disc? DVD9>4.4 gb?
I suppose this is an easy matter for the experts here but it's confusing to me.
Thanks!
Results 1 to 10 of 10
You could go with the ol' poor boy way and look at the bottom. Silver - 5, goldish - 9. That used to be the case anyway
And of course it's very, very rare to see a double sided disc with both sides being 9 (though I seem to remember one I had was 9 on one, 5 on the other side).. so usually if you have a disc with something on both sides it's going to be a dvd5 -
Actually, its:Originally Posted by Shudder
Purple - 5, single layer
silver - 9/10, double layer
goldish - 15, triple layer.
Can I just say because otherwise someone will try it, that you should not under any circumstances put a goldFish in your DVD recorder.
The capacity on them is terrible and besides, you have to drill a hole in them to let the drive's spindle hub go through. It's just not worth the effort.
Rich Tea biscuits are far superior.
Simple question on DVD+R DL discs/Capacity
By alegator in forum MediaReplies: 12Last Post: 19th May 2011, 05:52 -
simple question for experienced DVD player owners
By asmodeus718 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Apr 2010, 23:02 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 23:38 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 02:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 22:10
