Hi All,
Designing full-screen animation sequences in Flash MX (and perhaps other tools). Need to capture and encode these for burning on DVD.
Basically just need to capure everything on my PC screen to MPEG or AVI or whatever.
I know I could send the image out an appropriate video card and recapture it using video-in on another card. But this seems suboptimal and lossy.
Any ideas how best to do this?
-mredmond
Because I didn't know you could! If that works then that should be it.
Thanks! -
No problem. I've read that some people have had trouble exporting their animations as AVI. If you should run into problems there are other programs that will convert the SWF to AVI like Magic SWF-2-AVI.
Resizing screen output
By VenusAndMars in forum Video ConversionReplies: 3Last Post: 10th Nov 2010, 07:35 -
Output to DV instead of dual screen, import to another PC
By caseylite in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 6th Jan 2009, 10:10 -
screen capture output to dv stream
By bissquitt in forum Video Streaming DownloadingReplies: 12Last Post: 27th Jun 2008, 04:22 -
AVI split/screen output
By cinnamontea in forum Newbie / General discussionsReplies: 2Last Post: 31st May 2008, 23:08 -
How send 1-hr DVD over internet ?
By rdfarr in forum Video ConversionReplies: 11Last Post: 9th Apr 2008, 00:22
